lt160 only starts on ether
Old Oct 26, 2018 | 02:17 PM
msmccabe's Avatar
Default lt160 only starts on ether
92 lt160 quadrunner will only start on ether. It has fresh gas, carb cleaned and rebuilt.valves adjusted. At my last rope with this......Please someone give me some advise....
Old Oct 27, 2018 | 03:06 AM
First thing to do is check compression, less than 90psi and it is time to strip the top end down to find out why. One thing with ether, if the compression wasn't bad before you started using it, it will be if you continue, as it washes oil from the bore and rings, causing rapid wear.
jmbmichael
Nov 25, 2015 08:06 AM
ethernut
Oct 16, 2007 06:32 PM
0u812
13
Apr 17, 2007 09:38 PM
2lman
Mar 16, 2004 11:01 PM
KCRaptor
Mar 20, 2002 10:26 AM
