URGENT Zilla help needed, please
Old Apr 10, 2002 | 01:12 AM
Mr350X's Avatar
First, let me start by telling you about a noise the motor has started making.
Its a tick tick (VERY fast, consistant with RPM). It sounds as if its coming from the flywheel area. The flywheel seems to have no play, or VERY VERY little anyway, so I dont think its the crank bearings. They seem fine. Anyway, my Zilla is now (same time as noise started) acting like it has a jetting problem. It is cutting out under WOT and wont rev worth crap. It is NOT the jetting though, I know this for a fact from a diagnostic ride and testing today. (besides, it ran great with the same jetting the other day)
COULD this possibly be one of the electronic things behind the flywheel has backed out a screw or something, and moved into contact with the flywheel, hence the noise. This could explain my cutting out problem. It does seem like an electronic/spark problem.
Does this sound feasable?
Thanks people, im supposed to go to Glamis this weekend. "urgent"
-Matt
Old Apr 10, 2002 | 11:00 AM
Duneaddict's Avatar
couple things to look at... The '87 models flywheels are prone to failure. Not sure if the '88 would be similar before they updated them.
where the hub is riveted to the wheel... the rivets sometimes shear off causing the two pieces to separate.. this usually takes out the stator when it comes flying apart.
when you take the cover off, are there any rust streaks on the flywheel? (from the center out)
You may be in the early stages of this happening. It could also cause the ignition/timing to act strange.
otherwise,
If you do have crank bearing problems (hard to detect unless you really jerk the crank/flywheel around) the seals could be losing crank case pressure, causing it to lean out... usually this doesn't last long before you smoke the piston.
It would be well worth your time to get a flywheel puller, and look underneath the flywheel... if it is rubbing on something, you'd see it clearly. You could also examine the back side of the hub while you're in there.
Hope this helps.
Old Apr 10, 2002 | 02:35 PM
Jason454's Avatar
Yes the flywheel could be coming apart. I bought a 1989 not running once because of this problem. Somtimes the ignition pickup comes loose too(on the outside of the flywheel). Your bearing are probly still OK as long as your motor is idleing down.
Old Apr 10, 2002 | 10:40 PM
Triple's Avatar
If the clicking noise is worst at idle but gets quieter under load, your connecting rod is going (big and/or small end).
Old Apr 10, 2002 | 11:35 PM
truckracer's Avatar
Check the flywheel stuff but.............. Mine was clicking and I pulled the head, I was able to rotate the piston a small amount. I the pulled the cylinder and found the crank end bearings were shot on the rod.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
