lt 500 clutch?
Old Apr 8, 2003 | 08:56 PM
gnjeff's Avatar
Default lt 500 clutch?
:confused does anyone recamend what kind of clutch to get. my bike will be makeing around 70 to 75 hp. so i think i would need one to hold up good.also any info on prep befor installing thanks.
Old Apr 8, 2003 | 11:35 PM
superkev's Avatar
Barnett Dirt Digger. The clutch is a little stiffer than stock, but otherwise is great. I'm not sure what HP numbers for mine are, but mine's not stock, that's for sure. I haven't replaced a clutch, so I don't have any info for you on that. Get a LT500 manual and you'll be fine. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 9, 2003 | 12:38 AM
Halfliter's Avatar
The factory clutch with Barnett springs is by far the best to use. The stock fibers have bigger slots for the oil to escape to. The Barnett fibers glaze real easy.
Old Apr 9, 2003 | 01:32 AM
LT250RSuperstar's Avatar
Won't a Hinson clutch basket make a difference? Like grab better?
Old Apr 9, 2003 | 06:38 PM
Halfliter's Avatar
Only if the Hinson allows you to use one more disk. Otherwise, if your stock basket is in good shape I don't see any advantage. Or am I maybe missing something?
Old Apr 15, 2003 | 08:27 PM
soonerzilla's Avatar
Just got don with my barnet clutch kit so far it is holding fine, I recomend it
Don't wast your money on the factory manual for the clutch i bought one for 60.00
for the clutch it told me nothing except to take the springs down even and criss cross bolts holding them down no torq specs
also soak the clutches in the same oil you use in the bike for 15 min. before installing the clutches
Old Apr 16, 2003 | 12:42 PM
theTICK's Avatar
I was told by LRD not to use the Barnett because it is to " Coarse" and leaves to much grit in the tranny oil. I have stock clutch with around 63 hp and it works fine.
Old Apr 16, 2003 | 11:20 PM
Mr350X's Avatar
I have an EBC race clutch kit, (includes one extra fiber, and one extra steel) and I run the Barnett heavy duty springs and it grabs VERY tight.
My Zilla might be pushing 70HP. -Matt
Old Apr 17, 2003 | 12:29 AM
theTICK's Avatar
Hey MR 350X
What type of pipe are you running on your Zilla? And what type of gas and oil (mix ratio) do you put in ?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
