What ramps you got?
What ramps you got?
I'm close to buying a Honda 300EX, now I've got a trailer but got no way of loading it onto the trailer. So I want to be prepared before I'll buy it and get some ramps... Any of you guys can recommend which one is any good? Of course the more expensive the better probably but I like best value/money... so far i found these ATV Ramps from OnSaleRamps.com
Thanks.
Thanks.
Yes that's actually what I was wondering, what to do when loaden, strapping them... between the wheels is a nice spot. Thanks!
I bought a set from advanced auto for $89 they are trifolds when folded up they are small and can be used for ramps to do auto mechanics with (they came with a stop to put on when using for this) they fold out and have chains that hold them in place so the ramps dont slide on you
I have a bifold that is 48 inches wide. barely wide enough. Mine also did not come with any sort of strap to fasten it to the truck or trailer to leep it from sliding around. (I have seen countless numbers of guys get halfway up a ramp, it moves, they roll over. Even done it myself) Mine are not wide enough to make me feel comfortable. Also Mine do not have any side plate to keep a mud slick wheel from moving sideways as you ride up the ramp and the wheel starts spinning. I plan to mount some expanded metal on mine to give positive traction under all conditions. I'd sure like to find some wider ramps, but unless you go with two piece units, that isn't going to happen either. Which is a shame because the quads are getting wider as time goes by.
