What kind of grease for vbelt
Old Jun 28, 2005 | 09:40 PM
radmacks's Avatar
Default What kind of grease for vbelt
I know I should lube up my vbelt and pulleys but what should I Lube with and where Thanks for any an all help
Old Jul 1, 2005 | 11:26 PM
hellyeh's Avatar
Eternal Rider
Building A Runway To Hell & Back!
The engine is the heart of an airplane, but the pilot is its soul. ~Walter Raleigh
Old Jul 2, 2005 | 12:17 PM
Doctorturbo's Avatar
GOT BOOST!
This is a joke, right? If not, my best advice is get a manual for your quad. It won't be running long if you don't.
Old Jul 2, 2005 | 02:51 PM
radmacks's Avatar
Nice reply ! I have the manual and it says nothing about what type or where. I thought this was suposed to be a helpful freindly place if you dont know the answer why even reply.
Old Jul 2, 2005 | 03:37 PM
GOT BOOST!
Let me get this straight. You have a quad (God knows what make or model, you never said) with a belt drive and you say your manual says that the "vbelt and pulleys need to be lubed".
1st. How am I (or andybody else on this forum for that matter) suppost to know what your working on? Could be a 40 Ford for all I know!!!
2nd. No manual in the world is going to tell you to "lube a vbelt". So that tells me one of two things: You did not read the manual, or you did not understand, or misinterpreted it. It might tell you to lube the sliders but definitely not the vbelt.
I would be glad (along with many other people in here) to help you. But I'm neither a mind reader or know what the manual says unless you tell me the true and full story here.
That being said; to help you, we need 1. the make and model of quad your working on. And 2. "exact" wording in the manual where it talks about "lubing the vbelt". Once we have this info I'm sure myself or someone else will be glad to help you out.
Old Jul 2, 2005 | 09:59 PM
Kodiak660's Avatar
Try this ...........Belt Drive Service
Old Jul 3, 2005 | 05:39 PM
radmacks's Avatar
thank you kodiak660. That being said it is a Kodiak 400 I have lubed the slide with lithium grease on my own assumption. Is there anything else I should consider? 2K3 Kodiak 400 ultramatic transmission
Old Jul 3, 2005 | 05:44 PM
hondabuster's Avatar
The yamaha service manual says to use Grizzly grease, which has been superseeded by the Ultramatic grease. All yamaha dealers will have this.
Others have used marine grease (its very water resistant), and ive used mobile one grease, and it seems to do just fine. Whatever you use, make sure its water resistant.
Old Jul 3, 2005 | 05:50 PM
Kodiak660's Avatar
Hondabuster is right.....I have used both when servicing the primary pulley and both the Yamaha grease and marine /or white lithium grease will work just fine.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
