Massachusetts trails
Old Mar 5, 2011 | 07:06 PM
  #1261
Originally Posted by cncpro
Hi MooseHenden,
Just took some pics 'specially for you. Hope this helps.
footpegs | Facebook
Edit: P.S. I did get a ****** block with the winch. I'll have to start bringing it along after I improve my cargo space.
Excellent. Had one more question. Are the pegs flat on the bottom, like a U-channel or are they a serated H-bar? Thanks again.
Old Mar 5, 2011 | 07:08 PM
  #1262
Originally Posted by beergut
ehhh! Just spent the last 3 hours bolting the winch to the rene- what a pain in the ***! had to remove just about the whole front end and replace stock brackets with new steel ones- now I just have to wire it
From comments I've read having a winch on the front of the Renegade 800 will help in the corners but be sure to stab the throttle going into a jump.
Old Mar 5, 2011 | 07:54 PM
  #1263
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
my review of the rene's handling... it's very temperamental in the corners and likes to be "connected" to the ground (even though that 800 rotax makes it
hard to accomplish)- it's a challenge to ride in the deep snow as it's constantly searching for something to grab on to- while in 4x4, if the rear tires are grabbing and the front are slipping, it really throws a fit and zig-zags all over the place as the fronts try to grab and the rears are pushing- it calms down in 2x4 or when riding slowly on slippery surfaces- These 27" 589's make it difficult also- instead of sitting "on top" of the snow- they like to really dig and dig like a shovel- I think they are more suitable for mud then snow.
Even though people say it's the same as an outlander- no way does the renegade handle the same as an outlander, very different- my outty 650's & 800's were very stable & happy in the snow (27" itp mudlites)- all this rene wants is dirt and throttle
Old Mar 6, 2011 | 10:39 AM
  #1264
cncpro's Avatar
It is a simple serrated piece of U-channel which is secured to the aluminum floor pan frame with 2 screws.
Old Mar 6, 2011 | 11:08 AM
  #1265
Trideer's Avatar
Hi Guys!! I live in Dudley. I notice some of you are in my neck of the words. Any chance your looking for someone else to tag along with? I just got my first Quad last summer. 2011 Polaris Sportsman 500. I'm always looking for a place to ride. I love the thing but haven't done much riding. Plowing this winter mostly. If your speed demons I may lag you down. I am a rookie!! I'm a forty year old that likes to putt through the woods. I'd love to meet you guys some time, and pick up some pointers. Thanks for reading. I'm not sure if this forum thread will send me a message that you replied but if not my email is trideer1@charter.net. Shoot me a message if your interested. Take care, Russ
Old Mar 6, 2011 | 11:17 AM
  #1266
Bobby002's Avatar
Hey Trideer, I'm also new..I think the riders on this board have something planned for March 12 in new hampshire...I'm hoping I will be able to make it and get my quad registered up there..Should be fun..Let's see what the response is like to your post...Good luck
Old Mar 6, 2011 | 05:38 PM
  #1267
Thanks for the info. I might have ordered a pair but with them being flat on the bottom I'd have to grind a bunch of plastic down. Not a big deal but I may just get some aluminum bar stock, clamp 2 pieces together and drill where they are hitting each other to make "serrations" and then cut them to size. If I get a 7/8" aluminum bar I can sandwich it in the stock plastic serrations and run a couple bolts through the floorboards. You've helped me get a good idea of what to do just from your pictures. My son's Renegade has even wider footpegs than the KQ so I was hoping they'd be narrow enough to fit. Thanks again.
Old Mar 7, 2011 | 06:53 AM
  #1268
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
c'mon troy- git those pics up!
Old Mar 7, 2011 | 07:18 AM
  #1269
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Moose- you should try to mount a set of the kick-up pegs like on the rene... I love'em. I found myself using the kick-ups a lot when standing- the angle felt more natural on my ankles when straddling the wide seat... Should be easy enough to make.
Old Mar 7, 2011 | 07:25 AM
  #1270
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
cnc- it's funny that you thought the rear brake pedal was frozen up on the rene- up to that point- I'd never even touched the rear pedal because in 08 can-am added a second hand lever for the front & rear brakes- That rear brake pedal is the tightest I've ever felt on any atv- maybe 1/4" to lock'em up solid!
