Has anyone had trouble taking out the screws holding the float chambers and throttle valve cover? Screw head stripping!
Old Aug 17, 2003 | 08:44 PM
DreDay's Avatar
Default Has anyone had trouble taking out the screws holding the float chambers and throttle valve cover? Screw head stripping!
i seem to be stripping the heads of most of them. i find that the phillips head screw is very easy to strip. has anyone had this trouble and does anyone have any tips on how to take out a stripped screw?
Old Aug 17, 2003 | 08:54 PM
RaptorRidr660R's Avatar
You can use a dremel and cut a big slot and use a flat head to get them out, or drill the head off the screw and use vise grips to get the rest out. I replaced all the phillips head screw with allen head bolts from home depot! Just take one of yours there and match it up with something better. cost me like a buck to replace them.
Old Aug 17, 2003 | 09:07 PM
BigScary's Avatar
put the screw driver on the screw........then give it a good tap with a hammer.......it will losen it b4 you strip it.......
Old Aug 17, 2003 | 09:54 PM
sixsixT's Avatar
Yep and use a screwdriver that's in new condition. Old phillips screwdrivers belong in the garbage.
Old Aug 17, 2003 | 11:12 PM
crispy's Avatar
before you go strippin anymore make sure that the phillips head fits FIRMLY and snuggly into the screw, i did the same thing with my air box lid screws. i found a smalller better fitting screwdriver and really pressed down on them, i got em out then
Old Aug 17, 2003 | 11:45 PM
03waryer's Avatar
Had the same problem...those screws are the worst! Try some small vice grips to break the screw loose they should also work if the head is already shot.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Stillonit
Aug 5, 2015 07:46 PM
sticky123
Jun 14, 2015 07:36 AM
