Advance-Retard Timing /w Stage 1 HC on Rap?
Old 10-14-2003, 12:11 PM
Ward660R's Avatar
Default Advance-Retard Timing /w Stage 1 HC on Rap?
Helps like a brick to the head. LOL J/K
Actually it doesn't help. I have looked for a picture and can't find one, so I am just going to order one and see. I want it for the advance myself. I was just curious on the other...
Thanks for the help Gary![img]i/expressions/face-icon-small-cool.gif[/img]
  #32
Old 10-14-2003, 12:16 PM
garyc660R's Avatar
Originally posted by: Ward660R
Helps like a brick to the head. LOL J/KActually it doesn't help. I have looked for a picture and can't find one, so I am just going to order one and see. I want it for the advance myself. I was just curious on the other...Thanks for the help Gary![img]i/expressions/face-icon-small-cool.gif[/img]
Ward, do you see where the recess is atop the key that I made there? THats where the flywheel comes in contact with the key and it lets the flywheel rotate further counterclockwise effectively advancing the timing. Advancing the timing will create more cylinder pressure....what compression and fuel are you running now?
  #33
Old 10-15-2003, 09:37 AM
Ward660R's Avatar
I'm running methanol on a 12.5/1 static comp ratio.
I kinda see what your drawing, I just can't figure out if the adv key is more narrow than than the stock key. It doesn't really matter though... I guess.
  #34
Old 10-15-2003, 10:06 AM
garyc660R's Avatar
I'm running methanol on a 12.5/1 static comp ratio.I kinda see what your drawing, I just can't figure out if the adv key is more narrow than than the stock key. It doesn't really matter though... I guess.
It is machined just like the stock key on the lower part that sets in the crank....but the top has an indention on 1 side too allow the flywheel too rotate counterclockwise a little more, thus advancing the timing.
slowgsxr97
03-18-2022 03:40 AM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
95wolv
07-17-2015 08:13 PM
Dirtbikemike1
07-11-2015 03:36 PM
Quick Reply: Advance-Retard Timing /w Stage 1 HC on Rap?
