blaster
Old Dec 6, 2003 | 06:21 PM
speedDemontrx200's Avatar
Default blaster
how often do u have to replace the pistion on the blaster.........do u even have to i know that u have to replace pistons on any 2-stroke dirt bike every couple of months.
Old Dec 6, 2003 | 06:27 PM
Mr45auto's Avatar
Default blaster
I've got a 97 Blaster with a buttload of hours on it still running the stock piston. In fact it hasnt had a single part wear out other than brake pads and tires. Engine bolts/screws do tend to vibrate out but loctite them and you will have a very reliable long running machine. Just use quality injector oil and remember to run the carb dry when you put her up and everything will be peachy!
Old Dec 6, 2003 | 06:29 PM
Default blaster
so u dont really have to replace them if u take care of it.
Old Dec 6, 2003 | 06:38 PM
Mr45auto's Avatar
Default blaster
If you run it alot then sure you'll eventually need to do that. On a 2 smoke it is a 1-2 hour job if you're unfamiliar with the process. If you've done it you can finish it under 1hr.
Old Dec 6, 2003 | 07:31 PM
Default blaster
so what do u suggest a blaster or 250ex?(im 6'2 175)
Old Dec 7, 2003 | 07:08 PM
roosthrower's Avatar
Default blaster
I suggest the blaster because it is quite a bit faster and the after-market is big for them. if you are 6'2 though you would be cramped on either of them. consider something a little bit bigger or at least be sure to sit on one before you buy one.
Old Dec 7, 2003 | 07:17 PM
crispy's Avatar
Default blaster
replacing the piston usually goes along with the norm. top end rebuild. this is about every 200 to 250hrs you have logged on the engine
Old Dec 7, 2003 | 07:51 PM
Mr45auto's Avatar
Default blaster
At 6'2" I'd suggest skipping the little blaster. The 250EX is targeted to much smaller beginner riders. The Blaster is also a small machine. I very highly suggest you look at a nice used Warrior instead or even better a 400ex. I wouldnt buy any of these machines new though, there's better available for the money.
Old Dec 7, 2003 | 08:07 PM
xRedxRiderx350x's Avatar
Default blaster
my friend has a supertricked 02 blaster blew it bored it and then blew the oilpump and maybe the engine again
Old Dec 7, 2003 | 08:29 PM
Mr45auto's Avatar
Default blaster
With the Blaster if you start modifying it you might as well do away with the oil pump and premix your fuel. Zero chance of failure. My relatively stock and reliable blaster still has the oil injection but I keep an eye on the light and everything works properly.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
