my friend cut 3/4 of his stock silencer off. good or bad?
Old Jan 24, 2004 | 07:38 PM
NichelsonRacing87's Avatar
Default my friend cut 3/4 of his stock silencer off. good or bad?
my friend has a 2004 Warrior that's all stock yet and he first took the baffle out of his pipe. now he cut 3/4 of his pipe off so there is only like a 2 1/2 piece of silencer left on it. i know about doing this to 2 strokes or with aftermarket silencers, but i never thought it was a good idea to cut almost all of the silencer off. will this burn his rings or will it be ok.
Old Jan 24, 2004 | 08:33 PM
WoodsRuner's Avatar
It may burn his rings, it will definitely burn his valves. It may also burn the top of the piston.
I am surprised it even runs.
Old Jan 24, 2004 | 08:57 PM
JakalWarrior's Avatar
Little paranoid arent you? I doubt it will do anything except sap power and annoy people. Im not 100% sure on how to judge what is enough pipe but ive been told its too short when oxygen can get sucked back into it and make it to the head to burn stuff.
Old Jan 24, 2004 | 09:56 PM
Kushman's Avatar
If that was an improvement, ya think the factory would have done that?
when i was a kid i screwed with things like that...a wannabe engineer...
Old Jan 24, 2004 | 11:35 PM
thanks guys it not that i really care cause it's his own fault if he messes it up i was just curious cause he's pretty dumb on quads and he thinks you can do stuff like that to them and it won't hurt anything. i'm not an expert on 4 strokes, but i know just about everything there is to know about 2 strokes cause it's what i ride and race.
Old Jan 25, 2004 | 12:44 AM
WoodsRuner's Avatar
Fact 1:
4-strokes require a certain amount of backpressure in the exhaust. Without such
backpressure, the heat from combustion rushes out the valve faster than designed
and burns valves, at the minumum.
Fact 2:
Without minumum backpressure, the air flow rate thru the engine is greater than design,
causing a very lean mixture, increasing the heat of combustion, aggravating the valve burning,
with the possibility of burning, even melting, the top of the piston, frying the the top ring, and
scorching the upper cylinder wall.
Not paranoia, just physics.
Old Jan 25, 2004 | 02:00 AM
Haymaker's Avatar
I was waiting for someone to bring up the lean mixture part, If he re jetted he may be alright for a little while.
Old Jan 25, 2004 | 03:20 AM
Yamaha660R's Avatar
Bad.
Old Jan 25, 2004 | 03:22 AM
Explain to your friend he is losing a lot of power.
Old Jan 25, 2004 | 10:54 AM
teambooger3's Avatar
Woods Runner is 100% right on. Rings,valves,pistonand cyl walls will all get burned to hell!!!!!!!!!. 4-strokes need Backpressure Your buddy is riding a hand grenade . get a dennis kirk book and get a DG or a Cobra pipe(rear section)delivered to your door for about $100. if not bring a tow strap.hope this helps,Dave
polaris scrambler00
Jun 20, 2015 08:49 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
