Cutting Warrior Front Fenders
Old Feb 16, 2004 | 12:03 AM
warrior68man's Avatar
Default Cutting Warrior Front Fenders
Hey I am really bored and want to cut my fenders on my warrior....do all i have to do is cut them rivets out and take that piece off then sand it down? or is it more compliccated? please reply soon cuz I feel liek doing this tonight
Old Feb 16, 2004 | 12:35 AM
ISmoKeUonMY350's Avatar
u can either cut them off but it is alot easier to get a drill bit that is a little biger than the center of the rivet and drill the center out and th black piece will fall right off but be careful up by ur gas tank
Old Feb 16, 2004 | 01:00 AM
then what could I use to cut them so the holes arent there?a sander? or should I use a sawzaw?
Old Feb 16, 2004 | 01:03 AM
RoostItUp's Avatar
Just drill the rivits out then with a small/fine wood saw cut off the overlap plastic around the whole fender with the holes in it. Then with fine sand paper go over the edges to smooth them out.
Old Feb 16, 2004 | 01:04 AM
Crotts's Avatar
I just used a utility knife to remove the mounting lip, just watch your fingers.
Old Feb 16, 2004 | 01:52 PM
K I drilled the rivets out, took the black things off, cut the lip things off using a saber-saw, and used an air-sander and and sanded some parts by hand...looks pretty good...thanks
Old Apr 4, 2004 | 05:47 PM
Wickedclownz's Avatar
Is it possible for you to post some pictures i wanna see what the result from cutting your fenders was thanks
Reactant
Mar 30, 2022 02:08 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Reactant
Jul 16, 2015 10:29 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
