Snorkeling Problem
Old Feb 19, 2004 | 11:13 AM
wickedwolf's Avatar
Default Snorkeling Problem
I have an 04 Wolverine which I have recently snorkeled. Still wants to stall in the water but no water gets in the air box. Everything is snorkeled except exhaust. Buddy of mine said my exhaust is to big causing it to stall. Just wanting to know what I could do besides snorkeling it. They make a silencer for it but I don't know if that will assist my situation or not far as back pressure.
Old Feb 19, 2004 | 11:15 AM
wickedwolf's Avatar
Also they make a torque stuffer for my fourwheeler and was wondering if this might help me out.
Old Feb 19, 2004 | 11:51 AM
Maddog419's Avatar
Mite be your vent lines on your carb, not sure on the wolverine. But on most machines you need to raise them up also.
later
Old Feb 19, 2004 | 07:28 PM
wickedwolf's Avatar
I've got everything snorkeled. Berts Dirt Works said that its a good possibility that it is my exhaust and the water is causin too much back pressure. Goin to Crosby this Saturday and rig a cheap exhaust snorkel to see if that is really the problem.
Old Feb 20, 2004 | 07:32 AM
atv123's Avatar
Have you put dielectric grease on the spark plug?
Old Feb 20, 2004 | 10:28 AM
wickedwolf's Avatar
Yeah I thought of that already and have already done that. Still stalls. I know these things aren't made for water but you got to go thru it sometimes to get to more adventurous trails, instead of riding on the same trails over and over.
Old Feb 20, 2004 | 10:42 AM
atv123's Avatar
How deep is the water? Have you double checked all the connections/fittings?
Old Feb 20, 2004 | 09:29 PM
wickedwolf's Avatar
The water is usually only up to the racks. It does good for a while but like right when I'm almost out it tends to stall. I have the 2 diffs, carburetor breather, and fuel tank snorkeled. Put dieletric grease on spark plug and the other connectors that were easy to take off. Tomorrow I'm gonna run some flex hose for an easy snorkel and see if that prevents it. Thanks for all the replies though.
Old Feb 20, 2004 | 09:52 PM
mudngrizzly's Avatar
something i found on water crossings is the steam off of the engine gets drawn into the intake and go to the carb also did you look at the exhaust when it stalls-- black smoke might indicate water on the ign just a couple of thoughts let us know what you find my bike does rhe same thing about every other time
Old Feb 22, 2004 | 08:50 AM
04grizzly660's Avatar
i have a grizz 660 and mine was spittering in a mud hole also and i learned to put it in low gear that fixed it,in high gear it just spittered and backfired with no power!it also died under water.is the wolv an automatic?
Nondem
Feb 22, 2020 12:20 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
