Loc Tite removal
Old Feb 24, 2004 | 05:03 PM
  #21
Ward660R's Avatar
Default Loc Tite removal
I got them![img]i/expressions/face-icon-small-happy.gif[/img] It didn't go too bad actually. I let them soak in acetone then heated it up with the little tip I had on the basket side, then just backed them out. Two of the came out easy, the third one was a little stubborn. It was the one I had stripped the worse and ground the sides flat to grip with the vice grips. I was worried about trying to drill them straight for an
EZ Out. I would have been pissied if I would have drilled into the threads. I used a #40 torx bit in the one I stripped so bad after I heated it up. Between it and a punch it came right on out.
Again THANK YOU ALL FOR THE HELP!!!!!!!!!! [img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 24, 2004 | 07:20 PM
  #22
Outlawlawndragster's Avatar
Kewl glad to here it
Hey can you put short studs in those and then use nuts for the hold downs?
Might work better
Jus a thought
Old Feb 25, 2004 | 02:40 AM
  #23
Ward660R's Avatar
Might work better
Jus a thought
No you can't, the oil pump gear is too close. You even have to use special short headed allen bolts to fit in there. Well actualy you might be "able" too, but I think it would be more trouble than its worth. These allens should have never had to come back out, unless you break the new Hinson basket.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
