Dumping the Throttle
Old Mar 4, 2004 | 08:14 AM
zslate's Avatar
Default Dumping the Throttle
When my warrior is at and idle and I dump the throttle it about kills it. It bogs down, sometimes it does kill it. What and how could I fix this? Also the rubber piece that is attached between the carb and the engine is taped up and it back fire through there sometimes. Thanks
Old Mar 4, 2004 | 05:08 PM
zslate's Avatar
Old Mar 4, 2004 | 05:26 PM
Flynbryan's Avatar
You just answered your own question. Tape??? Do you have a crack or a tear in the boot? If so using tape to fix it........not good. Buy a new carb to cylinder boot, then try it out. Right now your probably sucking raw air in through that crack.
Old Mar 4, 2004 | 05:36 PM
warrior007's Avatar
yeah fix that boot and try it again.. but dumping the throttle at idle will kill it anyway, usually. Did on my old warrior anyhow
Old Mar 4, 2004 | 06:34 PM
zslate's Avatar
Ok, think i will buy the carb boot thanks!
Pehter
Oct 3, 2024 11:00 PM
hueby
Nov 6, 2015 11:34 AM
wrencher82
Sep 28, 2015 10:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
