Pre mix ratio for Blaster?
Old Jul 16, 2000 | 03:40 PM
Blastermon's Avatar
What should I mix at now that i have the injector blocked off. I have heard 32:1 and 20:1 and a few others. Which of these should I use?
Old Jul 16, 2000 | 04:36 PM
Duner97's Avatar
I had the injector on when I had my Blaster, but I run 32:1 in my other quads. That's not too rich, or too lean.
Old Jul 16, 2000 | 07:44 PM
99fasterblasters's Avatar
Old Jul 16, 2000 | 08:04 PM
94DGblaster's Avatar
32:1 is good.
I've heard 40:1 works good for trail riding..you don't load up plugs.
BUt i never tried that
Old Jul 17, 2000 | 04:15 AM
radgumby350's Avatar
i run 36:1 mc-1 bel-ray oil and never had one problem with being to lean or fouling out plugs!
Old Jul 17, 2000 | 12:52 PM
THEXOTIC1's Avatar
Hey there Little boy (GUMBY) this post was for a Blaster no a banshee.
32/1 and you dont have to buy the block off kit just take the side cover off and remove the plastic gear. Also remember to close the small hole up on the carb where the oil injector hose went. then remove that usless weight and off you go. Best move to make on a blaster it will save you headaches later
Old Jul 18, 2000 | 03:58 PM
EdSmith's Avatar
"then remove that usless weight and off you go. Best move to make on a blaster it will save you headaches later"
I'm just curious, what sort of "headaches" have you had? I haven't had any trouble with my injection after 5250 miles and counting.
http://blasterville.freeservers.com/oil.html
Old Jul 18, 2000 | 04:07 PM
THEXOTIC1's Avatar
The oil injector line fell off during one day of ridin and boom there goes the top end and the lower crank bearing. I always pre mixed my 2 strokes. I should have done this one also. Oh well you learn the hard way.
Also How do u keep track of the miles. Did you install a digital counter like one for a bike. If so let me know what one you used and how u went about installing the counter.
Ahtatu
Sep 28, 2015 12:14 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
