04 grizzly clutch kit
Old 04-03-2004 | 07:57 PM
GSXRPred's Avatar
Default 04 grizzly clutch kit
anyone know who makes a clutch kit for the 04 grizzly? I do NOT want one from High lifter... Know of any others ?
Old 04-04-2004 | 12:14 PM
Sparky660's Avatar
EPI makes a clutch kit for the grizzly. They are the ones that make it for high lifter. I put one on my quad and it made a big difference on my bottom end.
Old 04-05-2004 | 11:22 PM
GSXRPred's Avatar
Anyone else make a clutch kit... I cant find any besides highlifter. There is no way im paying 200$ for a couple springs and a helix.
Old 04-06-2004 | 12:58 AM
Sparky660's Avatar
Erlandson performance
Old 04-06-2004 | 01:46 AM
GSXRPred's Avatar
I have 26s and plan on getting a pipe and filter... Which kit do I need ?
Old 04-06-2004 | 04:30 AM
Sparky660's Avatar
Go with the oversized tire kit. The taller tires change the gearing and this clutch kit helps to regain some lost power. If you have any questions about there kit drop them an e-mail.
Old 04-06-2004 | 10:31 AM
hitman1970's Avatar
GSXR which pipe are you gona get? I got the big gun and it killed my low end. I also got a K@N and went to a 160 main. Stlll a terd!Think twice about the pipe. Sorry big gun fan's. I tried 165mj,170mj, moved the needle up and down. Changed the plug and tried diffrent heat range plugs, air pilot screw in and out. After all the wasted time, money and worn out carb and tank bolts I went back to stock. Now I'm AOK. Other pipes are probably better I'm sure, stay away from big gun . Only my 2 cent's.
Old 04-06-2004 | 11:43 AM
GSXRPred's Avatar
Aye, Im going to get a white bros or IDS... maybe a HMF if I can get it cheap enough.
Old 04-06-2004 | 11:40 PM
GSXRPred's Avatar
so anymore clutch kits other then EPI ?
Pgbama11
01-16-2016 09:19 AM
TLC
Utility ATVs
09-16-2015 02:41 PM
roy.hawkins3@gmail.com
09-11-2015 03:35 PM
Pgbama11
09-10-2015 09:20 AM
cdstang
08-31-2015 08:52 AM
Quick Reply: 04 grizzly clutch kit
