Banshee Clutch Swap..
How would i go about changing out my clutches.. And how to clean the case like the clutch side where all the clutch particals lay.. What are some things i need to do. As in to not mess it up and fry something.. Thanks it looks easy got my old ones off and new ones on the way..
Thanks, charlie
Thanks, charlie
1 hr is fine, dont have to soak it that much, its still get wet once you put the oil in the case, i had everything in mine change when i went in there, basket and clutches, to change the basket you will need to drill out the rivets that is holding it onto the gear, and then replace the basket, remember 7 metal plates 8 clutch disk......start..clutch,metal,clutch...you should endup with a clutch @ the end....to clean the case out you can blow it out with a compressor and wipe it with a rag, or be carefull that the ball bearing dont fall out when you remove the plate with the springs on it...it has a ball bearing at the end of the rod that squeezes against the pressure plate when you engage/squeeze your clutch.....good luck..
Thanks a lot man.. Got the clutches on there way will be here thur.. And a gasket. got it all ready how should i clean the case out there are little clutch particales on the case , what about brak clean?.. I got the cover pretty much clean and gasket off...
Charlie
Charlie
cdstang
Aug 31, 2015 07:52 AM
