Times from my first 300' Sand Drag - update
Old May 30, 2004 | 01:25 AM
RaptorRacer1's Avatar
Default Times from my first 300' Sand Drag
Here are the times from my first two runs ever on a 300' sand track. First run was time trial to get a dial-in time. Second run was round 1 of eliminations.
First Run
Reaction .211
60' 2.106
ET 5.658
53.602 MPH
Second Run
Reaction -.017
60' 2.167
ET 5.873
53.267 MPH
Even though I red-lighted the 2nd run I still won because the other person red-lighted worse than I did. So how are these for my first time.
The first run I had an oil leak at the base gasket. The second run I had a cracked cylinder and it was spewing oil. Once I get that fixed, and with my new 21/12/8 ultralight 9 paddles I think I can improve quite a bit. I am hoping to get it into the low 5.0-5.1 range when I get the engine rebuilt and am running under full power. Then next will come a Boondockers nitrous kit.
What times are you other guys running on your Raptors? Am I even close?
RR1
Old May 30, 2004 | 01:46 AM
Yamaha660R's Avatar
I will post times and pic's tomorrow on my first drag race event that took place tonight. I'm just far too tired to fool with it now. But I will definetly get it all taken care of tomorrow in one big post.
Congrat's on the time, and I hope you get everything back together. I'm sure with tinkering and more break in you can get some really good times.
Old May 30, 2004 | 01:49 AM
bbertram's Avatar
How does your time compare to other raptor owners? Is 5.658 in 300' a fast run? How does 4.0 sound in 200'?
Old May 30, 2004 | 02:02 AM
BBERTRAM, I don't know how it compares. That is what I am trying to find out. I would like to know what other Raptor owners have run. Higher or lower. So I know what I have to improve on.
RR1
Old May 30, 2004 | 03:41 AM
bad350twin's Avatar
i ran a 4.9 and 5.0 at 330ft on asphalt last summer with my 686 before my new mods.....if this helps!
Old May 30, 2004 | 04:04 AM
14mins's Avatar
RaptorRacer- Not bad times. Your 60 foot is the area for your biggest improvement. With a little more track time and launching hard you should be able to get into the 1.9's. Your times are respectable. Tracks vary from place to place. The fastest raptors that i usually see run 4.9 and 5.0. It takes massive hp to get into the low 4's. Most 686's run from 5.3-5.8
Old May 30, 2004 | 02:00 PM
PipeIt660's Avatar
Mine is running around 5.0 flat. Nothing under 5.0 yet though in 300ft. In 200ft,
the best Ive had on the timeslip is a 3.92. This is all on dirt, with horrid launch zones -
and no wheelie bars. Im totally satisfied none the less, since Im on a pretty mild
build. I have LOTS of room to go up [img]i/expressions/face-icon-small-smile.gif[/img] It sure looks impressive when a mild 686 Raptor
is taking out 535 Cheetah Banshees and drag Zillas in 300ft of dirt .
Good luck, and Yamaha660R - Cant wait to see your results man, post 'em !
Old May 30, 2004 | 11:01 PM
Here is a setup question for you dragracers. With stock gearing and 22" paddles I bog just a little bit when leaving in 2nd. When leaving in 1st it winds up so fast that I have to shift almost immediately to second. Either way I have to shift to 4th just before the finish.
Should I go up a couple teeth in the rear and leave in second, or should I go down a couple teeth in the rear and leave in 1st? Or any other suggestions would be helpful. Thanks!
RR1
Old May 31, 2004 | 01:50 AM
Sandragggen's Avatar
Default Times from my first 300' Sand Drag - update
This has to be bracket racing (most tracks are) for a properly tuned 535 Banshee will demolish a 686 Raptor heads up...guaranteed.
JMiller
Old May 31, 2004 | 04:17 AM
WallStreet's Avatar
I was running stock gearing w/ 21-12-8 8 paddle haulers and it would do the same bog. I switched to a 12 tooth front and it pulls 2nd beautifully now. That is what I would do, cheaper and easier. I also have a 14, but I was happy enough with the 12 tooth-2nd gear launches that I didn't try it out.
Since nobody has asked the obvious, why the cracked cylinder? Are you going to have to buy a whole new jug?
Good luck with all,
St.
