Who uses YamaLube??
Old Jul 21, 2004 | 01:10 AM
Outlawlawndragster's Avatar
Default Who uses YamaLube??
There may be a tolerence issue some where else in the engine . If some other oil passage has opened up to far you would loose your pressure and volume at that point and may starve the valve train . Sounds like if they are going to deny you you need to get a machinest to spec out your engine on tear down and then go after them .
Old Jul 21, 2004 | 10:17 AM
modquad's Avatar
Hopefully Yamaha will step up to the plate.
Old Jul 21, 2004 | 03:18 PM
RoostItUp's Avatar
Knowing Yamaha, I doubt it.
Old Jul 21, 2004 | 03:54 PM
modquad's Avatar
Just talked to Pudl....you're right, they bailed. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 21, 2004 | 07:19 PM
  #15
RaptorOwner's Avatar
I use yamalube for better shifting, I have tried others and if you want to try and find neutral you will be trying a bit longer on another brand.
Old Jul 21, 2004 | 07:26 PM
  #16
warwgn's Avatar
yamalube is no better than anything else, it is all just personal preferance. If you run 10 different oils through a mass spectometer you will see very little difference in them, main difference is additives and detergents, but the rest is just oil and it all breaks down no matter what. the best bet is to just change it very often as you have. I would say your problem is a supply issue as stated above.
Old Jul 21, 2004 | 07:49 PM
  #17
modquad's Avatar
I just hope they run it through a mass "we'll stand behind our product" scope. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 21, 2004 | 08:00 PM
  #18
Goliath's Avatar
I use it on both bikes. Seems to work fine.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
WISTECH
Jan 27, 2004 09:12 PM
Y2JRaptor660R
Sport Quads
12
Jul 7, 2003 10:33 PM
BuckinHO
May 13, 2003 04:26 AM
sonic
Mar 29, 2001 11:32 AM
