Fixxing Banshee Clutch
Old Aug 4, 2004 | 01:14 AM
blindside350's Avatar
Default Fixxing Banshee Clutch
I'm redoing the clutch on my banshee, and what tools do you need to take it off/ put it back on. Also what is the best clutch kit? Tusk/ Hinson/ Barnett?
Thanks
Old Aug 4, 2004 | 11:57 AM
AlkyBurninX's Avatar
12mm wrench for the kickstarter, flat blade screwdriver for the coolant hose, phillips screwdriver for the cover bolts, 14mm wrench for the footpeg, 10mm wrench for the clutch spring bolts.
KG clutch factory kits work very well. I have them in my TT stroker motor. They are pretty cheap and any dealer should be able to get them
Make sure not to lose the ball inside the clutch when you pull the pressure plate off.
Old Aug 4, 2004 | 03:15 PM
FBOMBERS's Avatar
What he said on taking it apart.I recommend using Yamaha FZR clutch fibers with Barnett steels and springs.We run this setup on all of our drag bikes and recommend them to my customers.It will hold up to any abuse you can throw at it.Either run all the springs or run 3 stock and 3 Barnett,this will give a lighter clutch pull.Alba sells it as a kit and so does A&S Racing.
Old Aug 4, 2004 | 03:27 PM
WheelieKing's Avatar
Before installing the new fibers make sure you soak them in motor oil (same oil you would run in the crankcase of your bike). Adjust the clutch with the adjustment screw in the middle of the pressure plate and get around 1/4 inch slack. Also be careful tightening the clutch spring bolts because I accidently broke one. When you take off the coolent hose make sure you have a pan to catch the coolent so you don't make a mess. Also don't be fooled and take off that center circle plate on it because that thing is there for no real particular reason.
Old Feb 25, 2005 | 01:00 AM
MrG's Avatar
MrG
Hey fbombers i wanna get that fzr fibers,with barnett steels and 3 stock and 3 barnett springs kit. Where can i get it from and wat is it called.
thanks
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
