has any one ever tried 92 octain in a wolverine?
Old 10-23-2004, 03:23 PM
1ShotScott's Avatar
Default has any one every tried 92 octain on a wolverine?
it says in the manuel that it can help your bike run better. I have never tried it but I was wonderine if any one else has and could you feel a difference?
Old 10-23-2004, 03:44 PM
maddog56's Avatar
Default has any one ever tried 92 octain in a wolverine?
I cant believe that it tells you to run premium in a wolverine.
It will be a waste of money on a stock engine, octane does not make horsepower.
Old 10-23-2004, 03:55 PM
1ShotScott's Avatar
it won't give you more horse power it will just run better it says if it spits and sputters usualy running a higher octain will get rid of that problem.
Old 11-13-2004, 08:58 PM
mxer021's Avatar
thats all i run in my wolverine and i havent ever had a problem.
Old 11-14-2004, 01:09 PM
VelociRaptor350's Avatar
The higher the octane a fuel is, the harder it is to ignite. When you have a high HP car, the cylinder temp is hot enough to ignite fuel without the spark, so know the piston has to fight its way to the top of the stroke aganist the expanding combustion gases. This is refered to as a knock, or detonation. Running a higher octane means the fuel will not ignite just from heat, and makes engine feel super sexxy.J/k
Old 11-14-2004, 02:38 PM
OhHell's Avatar
I have run 87,,89,,and 92 in mine.
With the 92 it seems to have more low end torque but the engine runs hotter.
After running all 3 I now run the 89.
It seems to do best and run cooler and smoother with the 89.
Old 11-14-2004, 05:46 PM
4buy4's Avatar
When fuel ignites without a spark it is called dieseling . Pinging or detonation is caused by fuels of low octane ratings , improper timing , and a number of other things . Basically fuels of low octane rating will not burn under high pressures but will explode . Normal burn rates are in the 30/40k fps while exploding gases travel at a rate in excess of 80k fps . The resulting pressure wave from this action is heard as ping or " spark knock " as it strikes the piston dome and cylinder walls .Burning high test fuels do NOT hurt your 4 wheeler ! Also difficuly in igniting the fuel air charge is usually caused by a lean condition or faulty system components !
45 yrs exp & ase master certified
Gman
Old 11-14-2004, 06:58 PM
1ShotScott's Avatar
you must have had a fun time explaining that one to us. but I under stood it though.
Old 11-15-2004, 12:24 AM
Daranello75's Avatar
I've always run 91, in my toys. It really not a big deal $0.50 cents a tank for better fuel i'll take it every time
Old 11-15-2004, 03:28 AM
Blaster96's Avatar
I always run 91 oct.
Its safer than sorry.
4by4, thanks for explaining that. As I was reading I was worried I would have to...
Quick Reply: has any one ever tried 92 octain in a wolverine?
