Warrior: Adjusting clutch cable/reverse linkage
Old Nov 27, 2004 | 09:16 AM
Haywood's Avatar
Default Warrior: Adjusting clutch cable/reverse linkage
Does anyone have any expertise on adjusting my clucth cable? I just installed new clutch plates. It now engages fine, but under load (going up a steep hill) I think it is slipping still. I just screwed the clutch cable all the way in at the lever assuming this would be the best place to start. Do I have to go back in and adjust pressure plates or what? How do I know if that the clutch discs were installed correctly?
Second the reverse will no longer engage. I wanted to get some advice on how to go about adjusting the linkage before I mess something up worse than it is.
Thanks
Old Jan 11, 2005 | 01:46 PM
Haywood's Avatar
Anyone an expert in this forum?
Old Jan 11, 2005 | 05:21 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
idk but i need my cluthc cable adjusted also and need to know how ... i think ill make another post [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 11, 2005 | 07:01 PM
VelociRaptor350's Avatar
haywood that adjustment is for the freeplay in the lever, the actual adjustment is on the cable over the case, follow the line down and you'll see it.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
toonces
Aug 13, 2015 12:40 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
