problem with a warrior
Old Nov 29, 2004 | 07:37 PM
bullgator's Avatar
Default problem with a warrior
I got warrior for a cheap price and it has a problem.When I crank it up it dose not idle also it dose not rev up it just wants to stall and it back fires when you try to rev it up. It has a cobra pipe and I thought it would need to be jeted.But I heard it would be fine without it.I also cleaned the carb and changed the plug. Also I heard it is not getting enough air. what do i do Thanks guys
Old Nov 29, 2004 | 08:03 PM
orky4969's Avatar
I think you may still have dirty carb. make sure you strip carb completly and clean. sounds like dirty needle jet.
Old Nov 29, 2004 | 10:35 PM
bullgator's Avatar
I will try that thank you
Old Nov 29, 2004 | 11:12 PM
Gadjet's Avatar
Before you go taking the carb apart,try this. The reverse lever on the right side has two ground connections on it. Take the two allen bolts off the lever module an clean the frame around the first ground connection with a wire brush. The second ground connection is behind the lever held on with a small phillips srcew. Take that loose and clean with a wire brush also and put it all back together. I would bet a new carb that is what it is. Yamaha warriors are notorious for the electrical connections making that thing do exactly whats it's doing.The needle would have nothing to do with idle. The pilot and air mixture screw controls the idle in a carberutor.
Old Nov 29, 2004 | 11:14 PM
todster's Avatar
hows the compression?
Old Nov 30, 2004 | 12:38 AM
Sanddevil2000's Avatar
I had the same prob and it was a bad pos batt cable changed that now its fine
Old Nov 30, 2004 | 11:33 AM
orky4969's Avatar
please let us know what it was once you get it figured out.
Old Nov 30, 2004 | 06:34 PM
bullgator's Avatar
thanks for the great tips. that may be the problem thanks alot. also the conpression is fine. I will let you all know what the problem was.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
