Wheel Spacers...
Old 12-28-2004, 03:07 PM
PolishCowboyPL's Avatar
Default Wheel Spacers...
I have a question about wheel spacers in general... Which are better, the spacers that are just extended wheel lugs, and you just screw them onto the stock lugs. Urethane/Titanium spacers, or the solid metal ones. Each go up in price from each other but I am guessing the solid metal would be the most realiable but then again Urethane/Titanium weight less and revolving mass weights more. Also to get rid of the tipsyness, which I am used to already on my raptor, but to get rid of it... What size do I buy and do I need them in the front too or will just the rear do..
Finally what is the advantage of going with a longer axle instead of wheel spacers, besides a lighter wallet.
Thanks,
MIke.
Old 12-28-2004, 04:09 PM
SAW08's Avatar
I put wheel spacers on my raptor and it went through bearings like crazy but i dont know if it would give you the same trouble.......go with wider axle, my choice dura blue or LSR racing and you can get an axle that is adjustable in width
Old 12-28-2004, 04:28 PM
How hard is it to take off the axle and put a new one in? anyone konw the procedure?
Old 12-29-2004, 12:25 AM
MasterRaptor's Avatar
No big deal. Take off the right wheel and hub. Loosen the axle nuts and whack it thru.
Old 12-29-2004, 12:26 AM
Cool, thanks, I am not gonna buy one yet but if I do I'll sure to have more questions, cause an axle seems like a better deal then spacers.
Old 12-29-2004, 04:28 PM
quadbart's Avatar
In mho, there is no difference be tween buying a longer axle and putting spacers on. You still acheive the same thing. A longer axle. The longer you make the axle, the more stress it put on the bearings. Period.
I use spacers myself with no problems.
You can get em online at
Speed Trap Motor Sports . com
Old 12-29-2004, 04:32 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I would get the extended axle if you can, IMO I think wheel spacers are just a cheap way of widening a bike. If you do decide to get them I would only use them on the front. JMO!
Old 12-29-2004, 07:07 PM
Vinson581's Avatar
those spacers at speed trap i bet i would break in about 10 minutes of riding.
would i be ok with GOOD spacers like the g-force ones, they are strong i know. for the frount and rear if i only do jumping, and trial riding where the jumps are about 4 ft 5 ft in the air max?
Old 12-29-2004, 07:35 PM
blastergsx's Avatar
how to remove an axle:
1) Remove both wheels and hubs
2) Remove axle locknuts
3) Slide axle through the carrier (note: its best to elevate the swingarm by putting it on a piece of wood or something)
4) the sprocket and brake disc just slides off. remove the brake too, forgot to mention that as how i dont have rear brakes...
badgerboy1
09-26-2017 06:11 PM
10-10-2015 10:20 AM
Roro
Ask the Editor
09-30-2015 10:58 AM
tysonbully
09-28-2015 02:30 AM
r1pilot83
09-27-2015 07:38 PM
Quick Reply: Wheel Spacers...
Top
Follow Us
