new shocks needed with wider a-arms?
if u get +2 a-arms(+4 total +2 for each side, just making sure) do u need longer suspension, or can the stock suspension tide it over until i can get better suspension? thanks -------rider1169
Unless you get longtravel a arms, the stock length shocks will be sufficent. The problem isnt the length though, the stock shocks dont have the valving to handle the extra pressure. You will need new shocks if you want to jump or handle well at all.
+2 +1 (probably what your talking about?) A-arms do not need aftermarket shocks.. use stock shocks and you will feel the difference. Then save up $$ to get yourself a nice set of elkas!!!
If your on a budget get works..
If you have soem $$ get some PEP's or Custom Axis..
Originally posted by: Banshee392
Don't get elkas...
if you go plus 2, your going to have to adjust your current shocks, to a stiffer rate, the arm is out farther so the shock thinks their is more weight. i highly recommend just sending your stock shocks to TCS, and have them re-do them its cheap
I'd throw some yfz shocks on there, and if those arent enough have them rebuilt, not the stock raptors shocks. The yfz shocks have all kinds of adjustments that most recreational shocks like Elka's cheap line and works at steelers dont have. You also have rezzies.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
