**HELP** Raptor wont run right
hey guys ive been doin a lot of searching for raptor backfiring problems, but my problem seems to be unique. The quad had been standing up (on the wheelie bar) for 2 weeks. prior to being stood up the quad ran excellent for about 2 years before, it has a fmf power bomb header and exhaust and jetted. Now when it is started it fires right up in 15 degree weather idles excellent but as soon as you touch the gas it backfires and wont run. Rebuilt the carburator no difference whatsoever (not much of any particles in the carburator) im stumped i feel like it might be a timing issue or coil issue.
any help is appreciated, thanks Dane
what size jet are you running???? it sounds like you either have a partially clogged jet or are over jetting for the cold weather. One other possibility is your floats have shifted and now your floats are running too high. Did you drain the fuel out of the carb when you stored it. I hope this helps
Aaron
Aaron
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
