banshee clutch? fzr 600
Just do the entire barnett kit. It should run you between 100-115. give or take alittle. To get to the clutch you have to drop the clutch side case. So remeber to buy a new gasket when you pickup the clutch kit. Im not sure about coolant but I know you need to drain the engine oil. Its a good excuse to change the oil and filter anyways. Get a repair manual as the clutch kit comes with NOTHING. Good luck and remember its not that bad
Aaron
Aaron
cdstang
08-31-2015 07:52 AM
