Oil Nut on bottom of Warrior not coming off.
Old Apr 1, 2005 | 06:35 PM
Warrior02man's Avatar
Default Oil Nut on bottom of Warrior not coming off.
just went to change the oil and the lugnut thing underneath the warrior engine is not moving. I tried wd-40. Tried using a hammer and hitting the rachet so that it would move.. but it didnt. I need to change my oil badly, but the damn lugnut isn't coming off.. what should I do?
Old Apr 1, 2005 | 06:41 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
you put a socket on it and give it the ol' heev ho! left loosy man. take a small hammer and lightly tap on the plug for a minute that sumtimes helps.
Old Apr 1, 2005 | 06:46 PM
bberck's Avatar
put a pipe on end of ratchet for extra leverage just make sure sockets on good dont want the nut stripped
Old Apr 1, 2005 | 08:22 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
here's what you do... have a buddy or 2 help.. stand it up on the grab bar and put the socket on.. ( make sure it's a very strong wrench) and then put a LONG pipe on it and just go with it...
Old Apr 2, 2005 | 01:54 PM
DeathShadow's Avatar
Use a pipe or a breaker bar stand it up and give it a heav ho
Old Apr 2, 2005 | 09:56 PM
FoxForma's Avatar
if you still cant get it off you can just unscrew the clutch cover and drain it that way. Makes more of a mess but if you take it slow then you should be ok
Old Apr 4, 2005 | 06:45 PM
Roach007's Avatar
I know a couple of times I had to use a pipe wrench and just get on the outside of the Oil Plug, I even had to do that on my old Wolverine...
Old Apr 4, 2005 | 07:02 PM
RaptorOwner's Avatar
I dont know about them warrior plugs cuz I had mine do the same thing. I just never tightened it that tight again.
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
clsharky
Jul 13, 2015 02:07 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
rcappie4
Jul 10, 2015 04:54 PM
