How to make a warrior 400+ ccs
Old Apr 12, 2005 | 01:31 PM
Warrior02man's Avatar
Default How to make a warrior 400+ ccs
How do I do it? I ride trails.. so is it worth it? How much is it? thx.
Old Apr 12, 2005 | 01:37 PM
ZoomZoom14's Avatar
same here i'd like to find out how to do it
Old Apr 12, 2005 | 02:26 PM
NLWarrior01's Avatar
alba and powroll both make 400+ cc kits for the Warrior
the 400 kit when done properly is supposed to make around 30+ HP. You have to do some engine disassembly yourself I think and send the jug and piston and crank and such to them .. or just take the whole quad in. Bad04Warrior just had his finished up a short time ago and it seems to have wicked power from the video he posted .. you can ask him all about it.
Old Apr 12, 2005 | 02:38 PM
how much would they cost?
Old Apr 12, 2005 | 04:21 PM
no idea on the cost .. you're looking in the neighborhood of close to a grand I'm sure .. best bet is to contact them .. someone here should have that info. Mine's a simple 350 and no plans to update to larger other than maybe buying a Z400 [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 12, 2005 | 07:24 PM
Heapster's Avatar
I've been down the Big Bore Warrior route before, and I did the Powroll 400cc kit.
It was a 5.6mm stroker crank and .080" big bore.
Ported and polished the head on their flow bench for documented 10-30% flow gains.
Went with the .430/.430 high lift cam over the stock .380/.382.
I was able to hang neck and neck with 400ex's, but any of todays newer quads like a Z400 would most likely smoke a 400cc Warrior.
The warrior is just a dated 2 valve head motor, and the frame geometry and suspension is quite outdated too. I was running Works Shocks with dual rate springs.
Would I do the big bore again? NOPE, all said and done you're going to put close to $1200-1500 into the motor to do the full package with head and cam, and with any gain that adds 25-40% over stock, reliability goes way down too. I was even running a oiler cooler too.
The 400cc Warrior motor also grenaded after only 2 years and threw the rod punching 2 large holes in the lower case totalling the whole motor.
You'd be MUCH better off saving that $1500, selling your Warrior for $2500-3500 depending on the year and condition, then just putting all that money towards a newer quad like a YFZ450, Z400, Honda 450R, or what I did was get into a 500cc Predator and I've never been happier.
check out my website in my profile for the 400cc Warrior section in detail with flow bench chart data.
Old Apr 13, 2005 | 07:39 PM
pocha's Avatar
it will cost around $1,400.
Old Apr 13, 2005 | 08:24 PM
Heapster's Avatar
Yeah, what Pocho said.
Zoom Zoom, keep it rubber side down.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 16, 2015 10:29 PM
