im so depressed
Old Jun 17, 2005 | 07:46 PM
  #31
speedped79's Avatar
Default im so depressed
wats a stator lol
Old Jun 17, 2005 | 07:50 PM
  #32
UltimateAussie's Avatar
if your not kidding its the thingy that makes the power to charge the battery and produce spark
Old Jun 18, 2005 | 01:53 PM
  #33
emeraldisleatv's Avatar
glad to hear you found your prob
Old Jul 9, 2005 | 12:36 AM
  #34
420Pimp's Avatar
electric is confusin man
Old Jul 9, 2005 | 11:25 AM
  #35
AnimalMother85's Avatar
let me help out a bit here with electicity
electricity, look at it like water
psi=amperes
volts=volume of water
ohms=resistance/or some kind of pressure regulator i guess you could say
if you have a hose, with a Y in it, to two hoses, one hose up, and one hose down, the water is gonna flow down, to the path of least resistance. same as electricity, i.e. i had a shorted wire in my banshee wiring harness, i thought it was the cdi box, or the coil, or the stator, so before i chased my tail, i checked continuity(resistance), and there it was, right after the connector from the stator to the harness. Not saying that it'll magically point to it, i did have to chase the wires in my wiring harness first. What i'm saying is, when you have electricty, its gonna want to go to the way of less resistance, and if you have a short in the wire, its gonna be to the new ground(at the short), not through the cdi box, coil, wires, and spark plug(s) I would really like to be able to draw something for you, but i don't know how to do it and post it, i think that would really help you out. So...check continuity with a digital volt meter(you can get a cheap on from a auto parts store for like, $30) and its just good to have around, or check with a neighbor, they may have one, if you live on a farm, you definalty should have one somewhere. Also, keep you head up, I know what its live on a farm, it has its pros and cons, and when things really seem bad, i had a drill sergeant tell me way back in the day of basic, "well, atleast your not getting shot at"
I hope this was of some help, PM me if you have anymore questions.
Old Aug 28, 2005 | 05:49 AM
  #36
420Pimp's Avatar
man i wish i knew as much as you know about electricity it would be a big help in life and it sounds like drivin a car, once you learn it u no how to do it for life. What im sayin is it seems alot harder than probally what it really is to learn.
Old Aug 28, 2005 | 01:00 PM
  #37
well im not sure who dug this post from the grave but i found the problem it was the stator i got a new stator for it from yamaha, what a rip off, bu8t it startted fine. the problem with the bike now is the starter clutch making noise. so i got one off ebay. then my local dealer screwd me becuase of their laziness and now i have to weight a week for a part.
MikeyBoyesq
Aug 10, 2015 11:11 AM
tuffEnuf
Apr 15, 2005 12:19 PM
DaveBoyd
Mar 16, 2004 12:41 AM
BayouBlaster
Jul 20, 2003 01:49 PM
BayouBlaster
Jul 15, 2003 06:56 PM
