Cant figure out why its flooding
Today I figured I would try to start my blaster up.Well,I cranked it over a few and did noting,the exhaust smells like gas.So i looked at the plug and it was all gas up(brand new plug)so i blew it off with the air and blew inside the cylinder and tryied but wouldnt.So I took off the carb and reed and blew them out and took the carb apart and blew it out and retried and noting,just flooding again.I pulled the plug and put it in the plug-wire and to see if theres any spark,but non.Last time this exact thing happened,i just waited a day and it started.Anyone got any quite suggestions?Were going to the dunes on sunday and NEED to get this thing runnin.Any help would be appreciated.
Get a new plug, If that has spark then your in luck. Just try pushstarting it down a hill in 2nd gear held wide open.
If you get a new plug with no spark, then youve got ignition troubles, bad coil or stator.
Good luck!
P.S. I wouldn't be blowin compressed air into your engine, along with it being able to blow dust and dirt in there, it also blows moisture in there. Water vapor is made as you blow compressed air.
Good luck!
