2005 Kodiak 450 Air Filter ???
I would go with a UNI filter. I had the origional foam filter in mine and my sparkplug was always black indicating it could use more air. Since adding the UNI filter (which is foam also) my spark plugs are light grey which is the color your looking for. The UNI filter will require filter oil so be sure to get some of that, filter cleaner, and filter grease so it makes a tight seal when u reinstall your filter cage in your airbox. Now sure the K&N is a nice filter and will let even more air into your machine but I don't think u want to do that unless you plan of rejetting your carb and if your doing that you would want to get a new excaust to really notice a diff. But if you like me and just want a slight improvement in performance and to make your sparkplug the correct color (if its black like mine was) go UNI.
I'm using the UNI filter for about the last 500 miles. No problems here. I even put one of those billet exhaust end cap on the muffler. The hole is about twice the size. Mine seems to be running good with this set up.[img]i/expressions/face-icon-small-smile.gif[/img]
fordfaithful21
12-07-2015 05:52 PM
