any body ahs 27" tires i would like ur help
Old 09-28-2005 | 05:21 PM
harmoniefarmboy's Avatar
Default any body ahs 27" tires i would like ur help
im 15 and i just bough a grizzly i bought 26 in swampwitches like about 2 months ago but i guess they dont have enough traction for my liking
so i want to switch to some 27" mud bugs cuase i had them on a previous quad and they hooked up great
my 26" rub a little when my suspension drops and i was wondering how much would i have to shave off the back fenders? or would it just be easier to buy 26" mud bugs
Old 09-28-2005 | 06:48 PM
HooPharted's Avatar
i have 27" mudzillas,and a set of 27" bear claws,they rub a little bit when hitting a bump,but not real bad,,,,i just took my bike into the dealer today to have the gorrilla's,and the clutch kit installed,and when i get it back (hopefully Monday) ,im going to put the lift kit on next weekend,i was waiting to put the lift kit on before i did any cutting,because it may not be necessary afterwards
but i only rub on the rears towards the front of the tire,lower towards the back of the footrest,,,,,i also have spacers which probably help the fronts from rubbing,,,hope this helps
Old 09-28-2005 | 08:45 PM
ridinhigh's Avatar
If you have factory wheels 27's will not rub. If you use aftermarket the backs will rub so you'll have to saw zaw a bit off. Unless you use Gorilla axles like HooPharted is, don't use a lift. Thats a lot of stress on OEM axle's. You will be quite fine with 27's
Old 09-28-2005 | 08:53 PM
OGGYDOGGY's Avatar
check out my pics , the one titled CLEANED UP there is a good view on how I cut my rear fenders , I think it looks good. and it does not rub.
Old 09-28-2005 | 09:38 PM
WOW ur guys quads r flippen nice
one more question on the inside of the front fenders my 26 in tire almost rub with stock wheels and no wheel spacers would there be a problem there?
Old 09-28-2005 | 09:41 PM
do yall think i should just stay with more aggressive 26's?
its not like i go mudding only, becuase its pretty dry here but i have a couple holes to go in that stop me real qwik, but yea its mostly trails
what would u guys do? go bigger or just stay put
Old 09-28-2005 | 09:46 PM
ridinhigh's Avatar
well, with 27's a clutch kit is a must. 26's would be ight, heck with 27's you'd only gain another half inch anyways over 26's. Depends on how cool you want it to look.
Old 09-28-2005 | 11:02 PM
thanks alot
ur right about it doesnt get much more lift and it prolly would hav to have a clutch kit and im feeling pretty poor right now lol i like ur truck its pretty danm nice
thanks a lot
Customer Service #1
05-15-2020 08:46 AM
JackTheKing
Sport Quads
11-04-2019 06:06 AM
awer1968
09-08-2015 11:02 AM
MikeyBoyesq
09-07-2015 10:44 PM
Quick Reply: any body ahs 27" tires i would like ur help
