many problems
Old Nov 12, 2005 | 08:23 PM
raptorider660's Avatar
Default many problems
My raptor only starts with the choke on if i take it off it dies
Also i pull in my clutch and i hit down the first and just stalls i jump foward like if i didnt pull in the clutch
and my valves click alot but i adjust them
Old Nov 13, 2005 | 06:26 PM
Fahq's Avatar
My raptor does the same thing when I cold start it. Personally, I am not a big fan of running the bike cold, or on choke. I tend to turn the idle up a half turn when I start it cold. That way, I don't have to use as much choke. Once the bike is warm, I turn the idle back down. It helps prevent fouling plugs too.
Old Nov 13, 2005 | 09:45 PM
themadwarriorrider's Avatar
i just had the same problem 2 days ago with my 04 raptor 660, i just changed ther plug but it was early in the morning and about 45 degrees outside. i ended up getting it started and later that day i adjusted the idle on the bike. made it idle up a little bit. it seems to have fixed the problem, but the bike ist still cold natured in my book compared to the warrior i used to have or the bear tracker, i guess the bigger the motor the longer it takes to start them and warm up.
Old Nov 14, 2005 | 03:54 AM
Starky's Avatar
Be carefull messing with the idle adjustment expecially with the 01 Raptor. The Raptor is supposed to idle pretty high. When you turn it down you risk stalling the motor and having it kick back and destroying your starter one way gear.
Old Nov 14, 2005 | 06:43 PM
well i did make it really low maybe thats y but i still dont know about the rest of the problems
Old Nov 14, 2005 | 08:24 PM
Billiam11's Avatar
ur right with the raptor idling high
Old Nov 14, 2005 | 10:32 PM
Starky's Avatar
Put in a new spark plug, more than likley you have fouled it out. I highly suggest switching to a platinum spark plug. They cost more but I never had a problem with fouling plugs after I switched.
Old Nov 14, 2005 | 10:46 PM
can i get those at yamaha or somewere else and please help wit my other problems
Old Nov 15, 2005 | 01:11 AM
TheAdmiral's Avatar
well i have an 03 yahama raptor and i dont have any problems with it doing any of that. mine only starts with the choke on when its cold but in the summer i dont have to use it. maybe you should have that clutch checked out cause when mine when out it was doing that same thing when i tried to put it in gear.
2003 yahama raptor
Dyno jet kit
k@n filter
yosh headpipe and silencer
barnet dirt digger clutch and basket
stage 1 hotcam
protaper bars
prm front bumber and rear grab bar
prm nerfbars
razr tires and itp wheels
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
