banshee clutch
Old Nov 16, 2005 | 10:11 PM
Dml39's Avatar
Default banshee clutch
my clutch on my banshee was working fine and all of a sudden it just let go i thought it was just the cable but it was we made the clutch adjustment a few times and it works but then lets go again because some how the adjustment nut keeps coming lose again so we bought i a new one but we cant get the ball that is behind it out and we dont understand whats wrong does anyone have a clue ?
Old Nov 16, 2005 | 10:25 PM
enFORCER's Avatar
Try using a small magnet or tip the quad on its side....
Old Nov 17, 2005 | 04:26 PM
Dml39's Avatar
umm actually i tried that to its actually stuck but move when u push in the clutch it just doesnt want to come out but what do you think the problem could be with the clutch what could have broken to worn out ?
Old Nov 17, 2005 | 07:21 PM
enFORCER's Avatar
Hmmmm, the magnet didn't work????? Well you could try this.... Take a welding rod or a similar steel rod that will fit. take and mix up some J-B weld and put a dab on the end of the rod. Now carefully hold the rod with the J-B weld on the ball untill it sets up.. Then let it set overnight..
Next morning pull the rod out with the ball attached... This should only be done as a last resort..
Now if you do try this remember, if you put to much J-B weld on the rod you will never get it out.
Old Nov 17, 2005 | 09:08 PM
MDS2106's Avatar
If the rod is mushroomed on the clutch arm side you will probably have to split the case
Old Nov 17, 2005 | 09:30 PM
enFORCER's Avatar
shouldn't keep the ball from coming out
Old Nov 17, 2005 | 11:26 PM
MDS2106's Avatar
More than likely the ball is welded to the rod and the rod end is mushroomed or even welded to the clutch arm..........
Old Nov 17, 2005 | 11:56 PM
Dml39's Avatar
no see if i push the clutch handle the ball and rod move then when i let go the rod goes in and i kno this because if i have a magnet attached i have to push the ball back my self so i kno its movin but i dont understand y it wont come out
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
