quad riders who used to kick start above 10 times to fire it up-- what did you do to make make it start in 1 or 2 kicks?
Old Nov 29, 2005 | 11:40 PM
HomeBoy15's Avatar
Default quad riders who used to kick start above 10 times to fire it up-- what did you do to make make it start in 1 or 2 kicks?
i changed my plug and nothing
a friend checked the compression and it was fine
the working option right now is to kick it something like 17/20/23 times to fire it up.
how did you do it thanks alot
Old Nov 30, 2005 | 01:57 AM
Dugyoot82's Avatar
try cleaning your carb..might have some dirt or oil sump in it...also change your fuel filter too.
Old Nov 30, 2005 | 02:19 AM
HomeBoy15's Avatar
carb has been cleaned and also the air filter/plug changed
compression is just fine (155 psi)
fuel filter has been changed by the guy i bought it from
Old Nov 30, 2005 | 11:20 AM
Billsner's Avatar
what altitude do you ride at? maybe your air/fuel setting? maybe your pilot jet? welcome to jetting
Glamis700's Avatar
How old is the fuel?
Do you have strong spark?
Old Nov 30, 2005 | 12:00 PM
quadzjr's Avatar
It might be lean. Does it start different when it is hot to cold? Does it start easier or harder cold? Try both choke on and off. Secondly there is always full starting it behind the truck [img]i/expressions/face-icon-small-smile.gif[/img]. It also might have a weak spark. A weak spark condition is really hard to pinpoint becaseu you will still see an arc when you do a plug/spark test.
Old Nov 30, 2005 | 07:51 PM
TheWeedman's Avatar
I just monkey'd around with it for a while, cleaned the carb, cleaned the filter, replaced and gapped the plug, thankfully i didnt have to mess with the jetting. Its a trial and error thing.
Old Nov 30, 2005 | 11:43 PM
CertifiedDunatic's Avatar
the most important thing is that the fuel is fresh, that you are getting a strong spark, that your filter is clean, that your bike is jetted correctly, that you do not push the throttle flooding the carb with fuel, and also that you get the kick motion down.
Old Dec 1, 2005 | 01:19 AM
velocyraptor's Avatar
i was having the same problem with my old lt and finally bought a carb kit, i cleaned all parts in carb cleaner and acid, replaced all seals, gaskets, jets, needle, pilot, and the floats where getting stuck, all it needed was a clean up and a tune up, but i got tired of it and decided it was time for a raptor, nothing beats electric starter
MikeyBoyesq
Nov 27, 2020 02:44 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
wildbill59
Jun 9, 2015 02:28 AM
1000gade
May 27, 2015 12:37 PM
eighthmercury
Jan 8, 2000 09:21 PM
