where's the TDC/timing mark access cover for Wolverine?
Old Dec 28, 2005 | 03:25 PM
nedflanders's Avatar
Default where's the TDC/timing mark access cover for Wolverine?
I'm going to be checking/adjusting valves on a friends Wolverine. I think it's a 2001, but i don't think the year matters for this. I've done a search in this forum and already found the specs. What I'm wondering is where/what do you remove to see that the engine is at TDC, with "T" mark lined up? ( I know to do adjustment on compression stroke, where rocker arms have a tiny bit of play).
THANKS!!
Old Dec 28, 2005 | 10:11 PM
95wolv's Avatar
The timing marks are on the left side cover, there is a large slotted round cover on the side,that is access to the bolt you turn the motor with, the timing marks are under the smaller slotted cap just above it. Always a good idea to take off the cam sprocket cover and make sure when you are at TDC, the cam timing marks line up too.
Old Dec 29, 2005 | 04:43 AM
will removal of any of these caps require a new gasket?
where's cam sprocket cover?
thanks 95Wolv. been awhile since I've seen you post. but you might remember me better as confusedbuyer.
Old Dec 29, 2005 | 06:49 AM
LotusPosition's Avatar
You won't need any gaskets. The cam sprocket cover is on the left side, at the top of the motor. It's a round cover, held by allen bolts. Personally, I never remove it for valve adjustment, as you say, when the rockers are "free", you are on the comp stroke.
Another way to check for comp stroke is to remove the spark plug, and look in with a small flashlight--you should see the piston high in the cylinder.
Old Dec 29, 2005 | 08:00 AM
95wolv's Avatar
Maybe if you should have put your nickname as confusedned, then I might have recognized you !!! I guess I don't post as much as some, I figure I only do that if I have something important to say, or can offer real help, I figured owning a Wolverine since ' 95 made it ok to post on this one !!
Old Dec 30, 2005 | 02:18 AM
that's a good guide to live by. [img]i/expressions/face-icon-small-happy.gif[/img] mama always said, "If ya don't have something useful to say, don't say anything!" wish i could learn to shut my big yap more! I try to help others where I can, kinda to pay back those who have helped me, and to save the wear & tear on the smart guys so they can deal with the tougher questions. Oh, except the Ford Crew Cab diesel forum, where it's become a chatroom of good friends yappin about everything.
glad this was one you decided to speak on! THANX!
Old Dec 30, 2005 | 02:22 AM
hmmm, thot i already posted this tidbit... but i don't see it.
I put a screwdriver with a long-enuf handle in the Spark plug hole. then when it comes out the farthest (from piston pushing it), I know I'm at TDC. only do this on hard to see TDC marks, or ones that don't seem to wanna line up. works well.
Joe454
Nov 20, 2020 01:19 PM
ReconBayou
Oct 16, 2019 02:24 AM
buddieboy
Dec 9, 2016 05:50 PM
BYC
Sep 25, 2015 02:10 PM
jbrewster94
Sep 23, 2015 04:16 PM
