sparks ignition advance key
Old Nov 16, 2000 | 08:05 PM
quad4's Avatar
has anyone installed one yet?
Old Nov 18, 2000 | 08:10 PM
ewilmarth's Avatar
Yes, I just finished installing and testing my key and I do believe it provides quicker throttle response and maybe a tiny bit of power. I am running without intake snorkel and I tested it with and without the spark arrestor. Definitely better without arrestor. It seems to spin tires at high speeds alot easier than before the key.
Now for the installation! I had to fabricate a puller for flywheel since no one around had one and I wanted to complete today. Then when you get the stock key out and compare to Sparks key you wonder what is wrong! The sparks key does not fit into the keyway in any direction but I decided to follow their instructions and proceed anyways. So I cleaned everything up reinstalled the flywheel with impact wrench and closed it up. You have to refill with at least one quart of oil if you drain the crankcase only which I did since oil and filter were changed recently.
Overall I think it is a worthwhile investment and if you have the right tools could be done in less than two hours.
Have fun with it ! I am waiting for my production version of header and silencer from Dustins which should provide up to ten more horsepower.
I am still looking for K and N air filter if anyone knows where to get them yet?
Old Nov 19, 2000 | 12:30 AM
quad4's Avatar
Do you think that sparks sent the wrong key since it didn't fit well in the keyway?.I had the same problem with mine.
Old Nov 19, 2000 | 12:13 PM
ewilmarth's Avatar
I am going to be calling first thing Monday morning to get their explanation on it. It sure surprized me.
Old Nov 19, 2000 | 12:33 PM
400exman's Avatar
I got they ignition adv. key too for my 400ex and I had to beat it in the crank slot! Debating whether or not to buy one for my raptor...
Old Nov 21, 2000 | 08:48 PM
quad4's Avatar
The guy at the bike shop told me not to put the ignition advance key in my raptor because the size of the sparks key varied so much from the factory key.He said it was possible too shear the key off after it was installed or possibly wear out the keyway on the crank.I don't know if this is possible but it seamed like a big risk for a $15.00 part I'm sending mine back.
Old Nov 21, 2000 | 09:17 PM
ScoobyDFW's Avatar
FYI: The CDI box that ron woods sells for the DS650 that eliminates the rev limiter, also has an ignition advance curve built into it - no key required.
Old Nov 22, 2000 | 09:41 AM
ERICsRAPTOR's Avatar
Where does Ron Woods sell this CDI unit? How muck do they run?
Old Nov 22, 2000 | 09:51 AM
ewilmarth's Avatar
I called sparks on Monday and they have sent me the wrong key said I would have the right one today to replace the 400EX key. That is probably what happened to you.
Old Nov 22, 2000 | 11:36 AM
ScoobyDFW's Avatar
Ron doesn't make CDI boxes for the Raptor. I was just pointing out that there are other ways to get ignition advance other than a key.
Jmuddin284
Jan 19, 2026 07:16 AM
ScopeZ_
Jul 28, 2015 01:44 AM
NatePerz
Jul 27, 2015 03:27 AM
Unzzy66
Jul 11, 2015 10:01 PM
D-Hagz
Jul 4, 2015 02:19 AM
