CDI ? Clutch kit ?
Old Mar 10, 2007 | 01:44 PM
18inches's Avatar
Default CDI ? Clutch kit ?
I have recently started putting some money into the grizz. My nexy step is going to be a CDI and a clutch kit. Should I do it? I know the clutch kit makes a big difference in the bottom end and I do run a 26 inch tire, but I do not know much about the CDI. What if any difference willl it make in the overall picture and who makes a decent CDI? Will it negatively affect anything? Any advice would be great.
Old Mar 11, 2007 | 11:45 AM
18inches's Avatar
none?
Old Mar 11, 2007 | 12:26 PM
skramblr's Avatar
I don't own a Griz, but here's my comment. Clutch kit on an automatic is a great mod. It'll help shift the power to where you need it. Example - on my scrambler 400 (2-stoke) adding a clutch kit let the engine built revs (RPM) before engaging. That bike needs the extra power at higher revs to pull harder. So a clutch kit helps get EXISTING power to where need it.
Note that changing the clutch spring/weights is can be fairly cheap and a great mod.
Changing the CDI - this is trickier. In General, most common reason to do this is to allow the engine to rev higher (moves rev limiter higher to get more power). On an automatic machine this doesn't help much (as the clutch will keep the engine from reving higher, too). Or maybe you have the 700 FI model? (you didn't say). Using a CDI you can change the fuel mapping. This again moves power around. You can tune the FI to make the best power where you need it (depending on how you ride). This is also a great mod for an FI machine, but will cost you more and take a bit of trial and error to tune it perfect.
Old Mar 11, 2007 | 06:24 PM
18inches's Avatar
Anyone know of a good clutch kit manufacturer?
Old Mar 11, 2007 | 09:13 PM
skramblr's Avatar
EPI is the performance clutch king.
https://www.erlandsonperformance.com
Hopefully someone on this forum will pipe in with a suggestion on weights/springs. If not, you can contact them and they have some knowledgable techs that can help.
Dalton also makes some good kits. Here's a link to their FAQ:
http://www.daltonindustries.com
Old Mar 13, 2007 | 04:45 PM
18inches's Avatar
no cdi info?
Old Mar 13, 2007 | 04:50 PM
ctateusa1's Avatar
Try bikeman performance for a CDI
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
