91 ymf 250 starter problems help
Old Jun 24, 2007 | 05:18 PM
rv's Avatar
rv
Default 91 ymf 250 starter problems help
it seems to spinn like a buger but not long enought to start the quad
- new barrery check good !
-starter motor serviced by specialist !
-checked out the rollers and gears and they are good !
-it turns motor over but only for a second then it disenguages !
thanks in advance for any replies
Old Jun 24, 2007 | 06:03 PM
toddmh's Avatar
hehe that thing should be in a museum..But did you check to see if its getting gas from the tank to the carb?And also what kind of shape is the carb in??
Old Jun 24, 2007 | 09:20 PM
rv's Avatar
rv
starts ok with the pull cord so the carb is not a problem (starter is not right) and this machine was in storage for most of its life its mint tires are almost mint !
Old Jun 25, 2007 | 07:07 AM
Fulcrum's Avatar
It might be the starter relay. Try bypassing the relay (really just a solenoid) with a wire from the hot battery post to the starter. If it works, the starter is fine and it's another issue with the system, whether it's the relay, starter button, or whatever.
Old Jun 26, 2007 | 04:30 AM
rv's Avatar
rv
the starter seems to spin ok and will turn the engine over for a few seconds but wont stay enguaged long enough to start it! [img]i/expressions/face-icon-small-sad.gif[/img] once it turns the motor over it will just disenguage and spin making that buzz noise that a electric motor makes when uncoupled ! [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 27, 2007 | 01:16 PM
Fulcrum's Avatar
It's probably the starter drive (bendix) then. See if you can get your hands on one and rebuild it. Otherwise it's time for a new starter.
Old Jun 27, 2007 | 02:34 PM
lucasislight's Avatar
i might be way off so someone chime in if i am.
does the ymf250 have a one way bearing? if it does then that could definately cause the problem.
the only other thing i can think of is that your missing some teeth on the starter, the flywheel, one way, etc...
Old Jun 27, 2007 | 11:34 PM
rv's Avatar
rv
yes it does have a one way barng in it but when i took it apart it seems to catch fine?
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
