Blaster Troubles
Old Nov 4, 2007 | 12:59 AM
  #21
Raptor8300's Avatar
Default Blaster Troubles
indi360 I did a search for your name and blaster service manual but I couldnt find the post. Do you have the link?
Thanks
Old Nov 5, 2007 | 06:02 AM
  #22
hotblooded's Avatar
As far as your compression, I would bet that it will be the exhaust side of your piston that is bad and maybe even broken off. If so make sure to get all the pieces out of the bottom end. I flushed with gas 3 times with the quad up side down. You will also want to check the groove in your connecting rod to make sure that there are no pieces stuck in there and also take a little screw drive and rotate the bearing to make sure it is ok. Milling the head will give you a little more squeeze in the cylinder, but this alone won't give you a real noticable difference in power. My one Blaster we took the head 40 thousands, the second we took I believe 80 thousands and o-ringed it. I don't know what your location is but when we put on the aftermarket exhaust we went to 350 main jets and raised the needle one notch and they seem to be running good.
Old Nov 5, 2007 | 05:10 PM
  #23
Raptor8300's Avatar
After pulling the piston it was damaged on the right and left sides right at the rings. The rings were ground into the sides of the piston. My mechanic told me that a burnt piston on the right and left sides means that it was run to lean. I'm sure I did this to my self as I ran some of my 4 stoke gas, has extra oxygen added.
I just finished removing the TORS and the oil injection system along with rebuilding the carb. All I need now is my cylinder back from the shop with the new piston.
Old Nov 5, 2007 | 08:23 PM
  #24
Slash182169's Avatar
b4 u put all that stuff on check play in the rod and rotate ur crank and check for severe marks on it...
Old Jan 24, 2008 | 01:38 PM
  #25
shift_racer7's Avatar
my blaster did the same thing...it stalled like someone just turned it off, and when its runnin the rpms are extremmely low...i get back to my house and the oil line poped off. and it wont stay on now...i revv it and quickly th rpms go down really fast...
Old Jan 24, 2008 | 09:30 PM
  #26
qsportgoat's Avatar
google "boomer rydin/dirty " great site for blaster how to"s
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
nastyblaster100
Sep 13, 2015 01:19 PM
