Dynatek CDI wolverine 450
Thats what I kinda hope Wolverine07. [img]i/expressions/face-icon-small-wink.gif[/img]
ross as far as what the cdi would do is that it would raise the rev limiter, probably change the ignition timing a little and possibly get rid of the reverse rev limiter.
The reverse rev limiter, when you put the wolvy in reverse and back up it will only let you go 6-9 mph, When you are stuck in a mudhole, steep hill, or trying to pull another quad out of a sticky situation by backing up it really hinders any progress to these operations if your quad is cutting out due to the rev limiter(it is designed to keep people from hurting themselves by going backwards too fast and running into something or turning sharp and flipping the quad). The reverse rev limiter kit allows you to turn it off as you need it or to turn it back on for kids or inexperienced riders to drive it normally.
Biskit I am sure that if there is enough call for it they will make it.
