99 warrior problem
Old Apr 28, 2008 | 09:48 AM
stswanson's Avatar
Default 99 warrior problem
if it helps the starter seleniod vibrates when i try to start it without connecting the bolts.
Old Apr 28, 2008 | 08:59 PM
Fendercover's Avatar
That could be from low voltage. Best bet is to pick up a cheap volt meter and check the connections. Also when you bought the new battery was it fully charged when you installed it? Or did yo have to fill it with fluid and charge it yourself?
Old Apr 28, 2008 | 09:42 PM
stswanson's Avatar
i filled it with fluid and charged it.
Old Apr 29, 2008 | 04:37 PM
StngGT350's Avatar
stswanson. you say it vibarates? well this is what i would do. even though your batter is new, it could be bad. so i would hook it all up. i would jump it from soemthing like another quad or a car. after all they are all 12 volts. i would jump it battery to battery and try to start it. if it starts well then it is your new battery. if not well something else. i would next try by-pass or jump the solnoid with a peice of wire or a screw driver. it should start. if not,, i would get a longer peice of wire and i would jump it direct from the battery to the starter. this off all things should turn the starter over. if it does not turn the starter from the battery to the starter, then i would have to say it is the starter because you by-passed everything inbetween. but if it dose, which i think it would, i would work my way back and find the problem. i know a guy who bought a battery for his quad that was way too small and did not have the amps to turn over his 450 and sort of had the same issues as you did. so make sure you have the right size battery
good luck!
Old Apr 29, 2008 | 10:28 PM
  #15
stswanson's Avatar
i know its not the battery because i can turn the lights on.
Old Apr 30, 2008 | 11:48 AM
  #16
oblytr8's Avatar
The battery can easily be working, but not have the necessary charge required to turn over the engine. Get yourself a cheap volt meter, and check the DC voltage coming out. You should see 12V +. Most fully charged 12V batts will read around 13.5, to 13.75V when fully charged. The volt meter will also save you a lot of "what if"s. You can check the presence of voltage all through your wiring path, to see where its getting left behind.
Old Apr 30, 2008 | 11:51 AM
  #17
pmcc37's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: oblytr8
The battery can easily be working, but not have the necessary charge required to turn over the engine. Get yourself a cheap volt meter, and check the DC voltage coming out. You should see 12V +. Most fully charged 12V batts will read around 13.5, to 13.75V when fully charged. The volt meter will also save you a lot of "what if"s. You can check the presence of voltage all through your wiring path, to see where its getting left behind.</end quote></div>
he's right, it can run your lights but not turn your bike over.
when you bought it did you charge it for 12 hours before you put it in the bike? if not it will work for a little while, then loose its nessicary charge... just a thought.
Old Apr 30, 2008 | 09:58 PM
  #18
stswanson's Avatar
i din't charge it for 12 hours, but for 2 instead because the place where we bought it from said it only needs a 2 hour charge after adding the acid.
Old Apr 30, 2008 | 11:36 PM
  #19
rrhodes's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stswanson
i din't charge it for 12 hours, but for 2 instead because the place where we bought it from said it only needs a 2 hour charge after adding the acid.</end quote></div>
You can't fully charge a battery in 2 hours unless we are talking "AA" batteries. Charge the battery for a full 12 hours.
Lights do not need much power. Someone here already gave you a great test. Grab some jumper cables and try to jump it from a "running" car. If it works it is your battery.
here are some tips for you.
When charging conventional batteries, loosen vent caps and ventilate charging area. A buildup of hydrogen and oxygen in the battery or in the charging area can create an explosion hazard.
If the battery feels hot to the touch during charging, STOP. Allow the battery to cool before charging again. Heat damages the plates, and a battery that is too hot can explode.
NEVER put the red sealing cap back on the battery once you take it off. If you do, gases will become trapped and could explode.
Make sure the vent tube isn't kinked or blocked. Otherwise, gases could build up and explode.
Properly connect the charger to the battery: positive charger lead to positive battery post and negative charger lead to negative battery post. Unplug the charger or turn it off before you disconnect the leads, which will cut down on the chance of sparks.
ABSOLUTELY NO SMOKING, SPARKS OR FLAMES AROUND CHARGING BATTERIES. Charging gives off hydrogen and oxygen, which explode if ignited.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
