warrior
Old Nov 12, 2008 | 09:54 PM
beefy46172's Avatar
Loves To Ride!
Default warrior
Well if the park brake is blocked off, you connect them at the switch on the park brake to disable the rev limiter for the park brake.
Old Nov 13, 2008 | 02:24 AM
Andrew's Avatar
Default warrior
yea when i hit the gas hard it would stall but it rev high and i dont know what you mean by the park brake is blocked off
Old Nov 13, 2008 | 06:53 PM
warriorslayers's Avatar
Default warrior
Did you mess with your idleing when it would rev right??? I would really look into the parking brake...Your Carb float may be stuck also... Did the quad sit awhile... I would clean the Carb good, Put the wires togather and try again make sure that your idle screw is set right also, hope that info helps
Old Nov 13, 2008 | 11:55 PM
Andrew's Avatar
Default warrior
i just rebuilt the carb do you mean the fuel screw but the the carb is set right i just dont know why it rev high and pop alot and die???
Old Nov 20, 2008 | 03:51 PM
  #15
Andrew's Avatar
Default warrior
what wires i need to cut any help will be great
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
