can i paint my exhaust
I know what you mean about the pipe that looks rusty but isn't. That happened to my warrior which has the same exhaust as the wolverine, it's like the pipe has been powder coated and baked with dust and mud.
I stripped mine down to bare metal and sprayed it with high temp paint, and for the most part it worked, but it tended to flake off on the highest temperature areas no matter what I did. The paint I used is supposed to be good to 1,000 degrees fahrenheit, maybe if you find something that could handle more heat you'd have better luck.
I used krylon bbq & stove paint, flat black, 1200 deg. thermo-guard protection,
I havent ran it alot since painting the exhaust but seems to be fine, this is on my
350 warrior. if there is a specialty autoparts store around you that deals with such things as race cars/hot rods they may have some hedder paint, I have seen some as high as 1800 deg. maybe google high temp paint and see what is out there.
mrtidy
02-03-2016 05:00 PM
Quadzilla Heritage
09-25-2015 01:39 PM
