Wolverine Lift Kit problem
Guest
Posts: n/a
My bracket looks nothing like the bracket in you picture miassmaro I have about 3 inches of space between my tire and the closest part of the bracket. I have had my lift kit for about 1 1/2 years with no issues. How long ago did you order the kit and are you positive the kit you got was for the wolverine 450?
Yeah im with this guy, Ive have had my for like 2 1/2 years and havent had one single problem. I will also add that I havent ran it with the stockers either. I have 14'' ITP's and 27'' Mudlites on mine. For the money u cant beat it. And from what I measures its 2'' lift and if u make ur shocks as stiff as they will go u can cheat an extra 1/2'' or so.
Perfex Lift Kit Bracket Pics
http://i375.photobucket.com/albums/o...LiftKit002.jpg
http://i375.photobucket.com/albums/o...LiftKit001.jpg
The front hole is the original location of the shock mount. As you can see it sits no further forward than the shock mount originally did.
#15
Ok so I've read a real mixed bag on the Perfex system. Like many on here I can't stand the stock ride of my Wolverine and also can't stomach $1500 for Elka shocks so $165 plus shipping for this kit seems reasonable. I have an 07 450 SE and would really like to be able to ride with much less fatigue.... you guys that have this kit on your Wolverines still like and recommend it?
Also - any other place to get it than here 31225
Thanks
Thanks
#16
Wolverine cuts out on top end
I have an '03 wolverine with a high performance intake mated to a K&N filter with a 150 jet in the carb and a step hotter plug in the motor. The problem that I'm having is that she seems to cut out in fifth when I have the throttle pegged./'ll be topped out then it'll sputter, then it'll pick back up and start all over again. This problem only happens in top gear. Do the 2003's have a speed/rev limiter on them? Or is there a more serious problem going on here? thanks for the help guys. -Rich
Oh, BTW, for my top speed trials I had switched back to the stock tires so that I could get every mph out of her that I could.
