Help ID this old Yamaha
Old Mar 19, 2020 | 11:15 PM
Brandon Patrick's Avatar
Default Where did you find what parts are interchangeable
Where did you find the info on the parts I just got one my self would love to know what bikes I can get parts from
Old Mar 20, 2020 | 04:44 AM
Check with any of the on-line parts suppliers like https://www.yamahapartshouse.com/oem...er-yfu1w-parts then check if whatever you need has the same part number on another circa 1989 Yam. I always thought they were 350s and they are not that rare, I often see them on UK eBay, forerunner to the Rhino, they would have sold better if they had been 4WD.
Old Aug 21, 2020 | 02:30 PM
Stephanie-lee Van Deventer's Avatar
Default Looks very much like the 350cc big bear but the ext version 1988 to 1989
Originally Posted by Malachi
I picked this up earlier today but not real sure what it is. Thought it was a custom job at first but after inspection I'd say it's a factory model. The motor has 229 cm cast into it so I'm thinking 225 or 250 shaft drive. It has high, low and reverse on a hand shifter and looked to be 4 or 5 gears on a foot shifter.
It's missing quite a few parts but might be able to put it back together if I can find out what it is and if there's another model that's simillar. It needs a carb, throttle cable and pull start assembly. Top end is most likely full of dirt, so will need a rebuild.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
