2002 grizzly 660 carb help
Im rebuilding a carb for a friend and im ok up until I saw that the needle the the carb had in it. the one in the carb had more slots in it then the stock oem rebuild kit came with. im wanting to put the oem in so what setting do I use. here is a picture of the two neddles.. new oem one look gold. thanks for any help
2.5 is a good starting point, the way to tell if your mixture needs tweaking is to run in low gear up to speed, then let off and coast, if it pops through the exhaust, you are lean, turn it out 1/4 turn at a time until it stops. If you get to 4 turns, you need to go up a size on the pilot jet. If no popping, turn it in until it starts, then back out just until it stops.
RedRancher
10-15-2020 01:45 PM
