Clutch probems
Old Jun 30, 2010 | 04:23 PM
ironhide17s's Avatar
Default Clutch probems
On my 03 660 I look at the end of the cable where it goes into the casing I see that when I pull the lever, the lever moves about half way in and the end of the cable where the casing is it moves a bit. But i don't feel any tension on the lever. Once I pull the lever all the way into the handle bars i feel the tension. But when i let go it lever only springs back half way i have to push it back the rest of the way.
If I adjust the cable at all it the clutch slips. Unless i'm just adjusting it wrong not to sure. Some times when i start it the bike wants to roll a bit with the clutch pulled in. Like i can feel it just kinda chuggin, or i have to hold the brake when i start it in gear cause it wants to roll ahead. I would like it set so that when i pull the lever it doesnt have to go all the way to the handle bars that way i can just use 2 fingers to shift.
I also have a hard time getting into gear and especially into nutral. Is my clutch almost done? and if so what clutch would be the best? im a very aggessive rider.
Thank for the help
Old Jul 1, 2010 | 06:48 AM
The Kid's Avatar
sounds like the cable is going bad
Old Jul 1, 2010 | 04:55 PM
The cable? how could it be the cable?
I thought maybe the return spring. Iv just never really had a cable problem before. I guess it could be that
Old Jul 1, 2010 | 06:50 PM
The Kid's Avatar
they can fray inside, if only a few strains of cable are still intact it can act like your symptoms you have
Old Jul 1, 2010 | 07:53 PM
Ok thanks Ill get a new and try it. Hope it works
Old Jul 2, 2010 | 06:38 AM
The Kid's Avatar
first undo the cable at both ends and pull the cable and see if it moves easy
Old Jul 2, 2010 | 10:02 PM
So pull on the cable to see if it moves through the casing with out friction or binding?
Old Jul 3, 2010 | 07:02 AM
The Kid's Avatar
yes sir
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
