Belt dressing O.K.?
Old Aug 28, 2010 | 09:08 AM
ridinallday's Avatar
Default Belt dressing O.K.?
Is it O.K. to use belt dressing on the drive belt (CVT)?
Old Aug 28, 2010 | 09:15 PM
Butch450's Avatar
Okay heres a dumb ?, is your belt slipping? If so I don't think belt dressing is going to help it but probrably make it worse. I know you probrably don't want to hear this but, you should probrably open up the clutch and check everything to find the cause of the slippage and then repair it. That is if your belt is slipping.
Old Aug 28, 2010 | 09:26 PM
codyspratt's Avatar
Thumbs down
not just NO ! but HELL!! NO!!! that's the last thing you want to do...
Old Aug 29, 2010 | 08:14 AM
bitterfitter's Avatar
If you've ever used belt dressing on mechanical equipment (air handlers, MAU's, etc), you'll see after a while it all gets worn off, and ends up in the belt guard. You don't want that crap inside your CVT housing, not to mention your clutches aren't designed for it, and might not operate right with the stuff in place. BTW professionally, we as a company, and I as an individual won't use it, as it seems to be useful for a day or so and then it's worn off. Belt and sheave condition and proper alignment are more important than a spray on treatment for long trouble free operation.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
